I want to maintain a folder for constraints. I am using quartus in tcl mode. Is there any option in tcl, mentioning the exact path for constraints. For Example :- I have this directory structure like RTL -> For all RTL Files Constraints -> Contains all the constraints Program -> Contains all the .sof and -.pof files. I like to mention in .tcl file that the constraints are available in Constraints folder.. How do I do that,,,, Is there a solution for that ??/ Plz let me know... Waiting for an early response. Thanks, Sri.Link Copied
Hope I've understood the question.
I think you need to do the following...set_global_assignment -name SDC_FILE Constraints/my_constraints.sdc
export_assignments
Thanks a lot for the reply... But What I need is ..... Can I read the settings file from a directory ??? ...... Let us say..... If I write all the settings in a file named constraints.qsf which in a directory named Constraints /...... Now from the .tcl file can I intimate the tool to take the constraints.qsf file from the Constraints directory .... Please let me know.. Thanks, Sri.- Mark as New
You may wish to consider breaking a bit from your traditional approach. What I have typically done is keep all the Quartus project files in one folder:
my_project | ---rtl (source code) ---altera (.qsf,.qpf,.sdc) ---generated (files generated by Quartus during compilation), you can specify this in the project assignments Jake
