16613 Discussions
Correctly using generate statements?
I'm trying to make a register in VHDL real quick. I have a simple DFF that I'm accessing as a component like so:
ARCHITECTURE Structure OF sixteenbitreg IS Signal output : STD_LOGIC_VECTOR(15 downto 0); COMPONENT onebitreg PORT (D : IN STD_LOGIC; en : IN STD_LOGIC; clock : IN STD_LOGIC; Q : OUT STD_LOGIC ); END COMPONENT; BEGIN for i in 15 downto 0 generate reg: onebitreg PORT MAP(regIn(i),en,clock,output(i)); end generate; regOut<=output; END Structure;
This doesn't compile correctly though, I don't think I'm doing it right.
Generate needs a begin.
I tried using loop instead of generate, didn't work
jcafaro10, yeah, a loop is not correct, I read it wrong. The generate needs a begin after
"for i in 15 downto 0 generate"
so it should be:
BEGIN
begin
end generate;
regOut<=output;
END Structure;
That doesn't quite work, do I need an extra end?
Here is an example of a generate:
example_generate: for i in 0 to 31 generate
begin
example_inst: entity work.example(rtl)
port map
example_clk => clk,
example_rst_n => rst_n,
example_signal => output(i)
end generate;
--- Quote Start ---
--- Quote End ---
no, not generally. A begin is only needed, if e. g. constants are defined within the generate.
The original generate example is correct except for the missing generate label.
See the exact syntax definition from VHDL spec for reference
--- Quote Start ---
generate_statement ::=
generate_label :
generation_scheme generate
[ { block_declarative_item }
begin ]
{ concurrent_statement }
end generate [ generate_label ] ;
generation_scheme ::=
for generate_parameter_specification
| if condition
label ::= identifier
--- Quote End ---
Syntax elements in square backets [] are optional.
Thanks I sorta figured it out
