I am now working in a project which needs to make the DE2 as a USB device.
I am trying to write my own VHDL firmware on the FPGA. Now I write some codes and can communicate with the ISP1362. I can read from the ISP1362 and receive a request from the host PC, so I write a reply packet to the ISP1362 but the host PC cannot receive anything and keep sending the same request. I want to ask if there is any example or tutorial for using the ISP1362? I want to know whether I have written wrongly to the ISP1362 or is there any other problems? As I check the demo from DE2 using the NIOS CPU as USB device, I downloaded to the FPGA and the PC detects nothing when I plugged into the USB device port. So I am not sure the procedure it uses to connect with the PC is correct or not. Please help in this. I have tried for weeks and still not yet found a solution to make it send a packet to the host PC. I can share the code if needed. THANKS.Link Copied
I want to ask if the reply must be 64Byte or can be any number of bytes?
And then validate the buffer?- Mark as New
Hi ,
I also want to do the same applicaton as urs. But as u sais, I tried with the demonstration examples and my PC does not detect the De2 board. Can u please share how did u manage to write the code in VHDL, i am really a beginner in this filed. Hope to hear from you soon.Thanking you in advance. Mahesh- Mark as New
Not very soon I guess, but hope this helps anyone who stumbles upon your post. Here is an example project, which configures 2 USB Bulk Endpoints in VHDL - enabling USB communication with the DE2 board without the NIOS II processor: http://mzakharo.github.com/usb-de2-fpga/ Hope this helps, Mikhail
