Intel® FPGA University Program
University Program Material, Education Boards, and Laboratory Exercises
DE2 LCD display
I'm trying to debug a code I've written, but I'm having trouble figuring out the values of some of my parameters while using the Altera Debug Client. I'm using the Altera DE2 board and I was hoping to display some results on the LCD screen
I found in verilog this command: DE2LCDDriver(parameter)
How would i convert that to C or C++??
Thanks!
does anyone have a copy of this library?
alt_up_character_lcd.h
#ifndef __ALTERA_UP_AVALON_CHARACTER_LCD_H__
# define __ALTERA_UP_AVALON_CHARACTER_LCD_H__
# include <stddef.h>
# include "sys/alt_dev.h"
# include "sys/alt_alarm.h"
# include "sys/alt_warning.h"
# ifdef __cplusplus
extern "C"
# endif /* __cplusplus */
* Device structure definition. Each instance of the driver uses one
* of these structures to hold its associated state.
typedef struct alt_up_character_lcd_dev {
/// @brief character mode device structure
/// @sa Developing Device Drivers for the HAL in Nios II Software Developer's Handbook
alt_dev dev;
/// @brief the base address of the device
unsigned int base;
} alt_up_character_lcd_dev;
// system functions
* @brief Initialize the LCD by clearing its display
* @param lcd -- struct for the LCD Controller device
void alt_up_character_lcd_init(alt_up_character_lcd_dev *lcd);
// file-like operation functions
int alt_up_character_lcd_write_fd(alt_fd *fd, const char *ptr, unsigned int len);
// direct operation functions
* @brief Open the character LCD device specified by <em> name </em>
* @param name -- the character LCD name. For example, if the character LCD name in SOPC Builder is "character_lcd_0", then <em> name </em> should be "/dev/character_lcd_0"
* @return The corresponding device structure, or NULL if the device is not found
alt_up_character_lcd_dev* alt_up_character_lcd_open_dev(const char* name);
* @brief Write the characters in the buffer pointed to by <em> ptr </em> to
* the LCD, starting from where the current cursor points to
* @param ptr -- the pointer to the char buffer
* @param len -- the length of the char buffer
* @return 0 for success
int alt_up_character_lcd_write(alt_up_character_lcd_dev *lcd, const char *ptr, unsigned int len);
* @brief Set the cursor position
* @param x_pos -- x coordinate ( 0 to 15, from left to right )
* @param y_pos -- y coordinate ( 1 for the first row, 2 for the second row )
int alt_up_character_lcd_set_cursor_pos(alt_up_character_lcd_dev *lcd, unsigned x_pos, unsigned y_pos);
* @brief Shift the cursor to left or right
* @param x_right_shift_offset -- the number of spaces to shift to the right. If the offset is
* negative, then the cursor shifts to the left.
int alt_up_character_lcd_shift_cursor(alt_up_character_lcd_dev *lcd, int x_right_shift_offset);
* @brief Shift the entire display to left or right
* negative, then the display shifts to the left.
int alt_up_character_lcd_shift_display(alt_up_character_lcd_dev *lcd, int x_right_shift_offset);
* @brief Erase the character at the specified coordinate
int alt_up_character_lcd_erase_pos(alt_up_character_lcd_dev *lcd, unsigned x_pos, unsigned y_pos);
* Macros used by alt_sys_init
# define ALTERA_UP_AVALON_CHARACTER_LCD_INSTANCE(name, device)
static alt_up_character_lcd_dev device =
ALT_LLIST_ENTRY,
name##_NAME,
NULL, /* open */
NULL, /* close */
NULL, /* read */
alt_up_character_lcd_write_fd,
NULL, /* lseek */
NULL, /* fstat */
NULL, /* ioctl */
name##_BASE,
# define ALTERA_UP_AVALON_CHARACTER_LCD_INIT(name, device)
alt_up_character_lcd_init(&device);
alt_dev_reg(&device.dev);
# ifdef __cplusplus
# endif /* __ALTERA_UP_AVALON_CHARACTER_LCD_H__ */
Hope The Above Helps....
Here I am posting some very rudimentary code that shows one way to drive the LCD display in the DE2 (very rudimentary code ....)
# include <stdio.h># include <unistd.h># include "system.h"# include "DE2_pio_regs.h"# include "altera_up_avalon_character_lcd.h"
int main()
int in, out;
alt_up_character_lcd_dev * lcd;
int len;
len =15;
lcd = alt_up_character_lcd_open_dev(CHARACTER_LCD_0_NAME );
// i 've found CHARACTER_LCD_0_NAME in the system.h file
alt_up_character_lcd_set_cursor_pos(lcd, 0, 1);
alt_up_character_lcd_write(lcd, "SOO REALLY COOL", len);
alt_up_character_lcd_set_cursor_pos (lcd, 0, 2);
alt_up_character_lcd_write(lcd, "... TWICE SO ..", len);
Hope this helps others....
alfa
PS I am using Nios II IDE 8.0 and and Quartus/SoPC builder 8.0sp1.
As I was learning how to do this i figured out that the name of some include files has changed.
For instance:
used to be:
Has anyone else noticed?
@foleyme (http://www.alteraforum.com/forum/member.php?u=3960
i'm trying connect keyboard to FPGA ( kit DE2 like you) and display on LCD green..can you give me verilog code of DE2LCDDriver(parameter)?I realy need it :)
you can use the LCD16207.
that will work.
hello everybody, i'm trying to display time and date on LCD ( board DE2 Altera) by VHDL code, can you help me with the code ? please, i'm a beginer. thanks you very much
I keep hitting this 'obsolete' thread... just FYI, as of Quartus 13.0sp1 the library is 'altera_avalon_lcd_16207.h'
Looking over that and the other docs should help...# include "altera_avalon_lcd_16207.h"# include "altera_avalon_lcd_16207_regs.h"
then you just treat it like a 'mostly avalon' device...
IORD_ALTERA_AVALON_LCD_16207_STATUS(baseAddress);
IOWR_ALTERA_AVALON_LCD_16207_DATA(base, data);
However... the LCD needs quite a few 'waits'... so don't try to do a lot of IOWR's in a quick sequence.. put in some waits.. try starting wtih 100usec between them to start.
