how to i able to read out the data which has been stored in the SDRAM?? currently using the Terasic 5MP camera and it already has that function where by once u click, it will stored the data in the SDRAM. so how do i call it out? really need some helps here and guidance.
thanksLink Copied
I try to test SDRAM chip. Kindly advice me when the example driver method is use to test the SDRAM and when the read and write functions (IORD & IOWR) are used to the same test
In the IDE when you create a new software project, there is a memory test template. You can create a memory test project and have a look at the code.
