Hi to all,
does anybody know how to add a custom sram to my Nios II system? I mean that I instantiate a Tristate Avalon Slave in SOPC builder that is compliant with my sram but subsequently I cannot select this memory inside "Nios IDE" on page "System Library" where I usually select "Program memory (.text)", ".rodata", "stack", "heap", etc... Thank youLink Copied
Can you connect your component to the Nios II? Version 7.2 yhad an issue witht his
--- Quote Start --- Can you connect your component to the Nios II? Version 7.2 yhad an issue witht his --- Quote End --- Thank for your reply. Yes, I can see all the output pins in the block.
Thanks to all.
User Viper21 from NiosForum figured out how to fix this problem. After creating a component, located and open up the .tcl file. Find the line "isMemoryDevice” and change the value from "false" to "true". Many thanks to him. However, I am astonished that there is not a check about it in SOPC builder...
