16613 Discussions
Quartus doesnt seem to recognize the new library
hi, ive been trying to use the library (ieee_proposed) i got from http://vhdlguru.blogspot.com/2010/03/fixed-point-operations-in-vhdl-tutorial.html in my design, but i get the following error in quartus:
Error (10481): VHDL Use Clause error at TEMP_READER.vhd(9): design library "ieee_proposed" does not contain primary unit "fixed_pkg"
i copied the library file to the library directories of quartus but stil i get errors
and ive included these line in my design file as instructed...
library ieee_proposed;
use ieee_proposed.fixed_pkg.all;
can somebody please help? ive attached the library file
regards
I normally use a short cut i.e. comment out library anf add pkg to quartus project(add files).
I love to know more professional way...
--- Quote Start ---
--- Quote End ---
Hi Kaz, thanx for your reply, it still doesnt work. maybe i need to add more files...
i've successfully used the Altera fixed point packages from here:
http://www.vhdl.org/fphdl/
i believe i also just added the package to the project, i'll have to check.
i am facing the same problem, how can i compile this package into the library "ieee_proposed"???
heh i never checked, let me look tonight
have you included fixed_pkg_c.vhdl in your design file list?
i made it work!
Thanx...
Hello all!
I have the same problem prompted in this thread.
How can I compile the "fixed_float_types_c.vhdl", "fixed_pkg_c.vhdl" and "float_pkg_c.vhdl" files into the "ieee_proposed" library?
A solution is to add them as external files (Settings menu-> Files -> Add), but I'd like to build up the library files so it would be more professional.
Thank you all
ps: I'm using Quartus II 9.0
Quartus ignores design libraries, so there is no need to assign everything to libraries. Quartus is also pretty crap at doing it anyway.
So I wouldnt bother.
So the way o use them is to add this files as "Global User Libraries" in the Quartus II Options panel?
