AI Tools from Intel
Find answers to your toolkit installation, configuration, and get-started questions.
AVAILABLE NOW! Intel Software Developer Tools 2024.0
Barbara_P_Intel
Intel Software Developer Tools 2024.0 Highlights
  • Intel developer tools now maximize performance on upcoming Intel 5th Generation Xeon Scalable Processors (formerly known as Emerald Rapids) and the Intel® Core Ultra processors (formerly known as Meteor Lake).
  • Improved installation directory layout provides faster environment setup.
AI Tools
  • Choose your AI target platform with broad support across Intel CPU and GPU hardware.
  • Experience significant performance gains across deep learning frameworks, machine learning libraries and Intel AI tools.
  • Get your AI tools faster with the new web-based AI Tools Selector, a flexible, streamlined process for precisely getting the frameworks, tools, and libraries you need, individually or in pre-set bundles.
  • Developers can now get more work done with faster performance using standard Python to deploy numeric workloads across multi-architecture CPU + GPU systems.
Intel® oneAPI Base Toolkit
  • Intel® oneAPI DPC++/C++ Compiler fully implements the SYCL 2020 specification, improving developer productivity and boosts CPU and GPU offload performance, and enhances OpenMP 5.0, 5.1, 5.2 standards compliance.
  • Intel® oneAPI DPC++/C++ Compiler adds popular LLVM sanitizers to easily catch C++, SYCL, OpenMP address, memory leak, uninitialized memory, thread data races, deadlocks and undefined behavior on CPU.
  • Several advanced preview features are available for evaluation including C++ parallel STL for easy GPU offload, dynamic device selection to optimize compute node resource usage, SYCL graph for reduced GPU offload overhead, and thread composability to prevent thread oversubscription between oneTBB and OpenMP.
Intel® HPC Toolkit
  • Intel® Fortran Compiler significantly improves productivity by adding popular LLVM sanitizers allowing developers to catch Fortran, OpenMP, OpenMP offload address, memory leak, uninitialized memory, thread data races, deadlocks and undefined behavior on CPU.
  • Intel® Fortran Compiler adds initial Fortran 2023 standards support and enhances OpenMP 5.0, 5.1 standards compliance.
  • With the first rollout of MPI 4.0 features, Intel® MPI Library developers can now easily pass very large MPI messages with more granular process grouping.
Intel® Rendering Toolkit
  • In addition to CPU support, the Intel® Rendering Toolkit libraries (Intel® Embree, Intel® Open Image Denoise, Intel® Open Volume Kernel Library, Intel® OSPRay and Intel® OSPRay Studio now support Intel Xe architecture-based GPUs (Intel® Arc™ and Data Center GPU Flex and Max Series).
Download Intel® oneAPI Toolkits TODAY!
