AI Tools from Intel
Find answers to your toolkit installation, configuration, and get-started questions.
DPDK memif driver
Raghavender
Currently dpdk memif code indicates that it can support only MEMIF_INTERFACE_MODE_ETHERNET mode.
Code: dpdk-20.11.1/drivers/net/memif/memif_socket.c
if (i->mode != MEMIF_INTERFACE_MODE_ETHERNET) {
memif_msg_enq_disconnect(pmd->cc,
"Only ethernet mode supported",
0);
return -1;
Is there a way memif can support pure raw buffer mode? So that pure raw buffer can be sent/received without any IP / UDP headers?
If we just allow the mode with MEMIF_INTERFACE_MODE_PUNT_INJECT, will it be able to handle raw buffer mode ? OR without IP/UDP headers the packet will be dropped by any other node from dpdk side ?
Can someone pls share the ideas / thoughts on this part?
Along with this is there a way we can test dpdk with memif in a standalone environment?
Thanks & Regards,
Raghavender.
Sazirah
Hi Raghavender,
For support with DPDK we will need to redirect you.
Kindly refer to DPDK.org or open an IPS case at IPS Support
After registration, you will be able to open a case on the Intel® Premier Support (IPS) platform and your request will be handled by one of our engineers as soon as possible.
https://www.intel.com/content/www/us/en/support/articles/000057045/ethernet-products.html
Sazzy_Intel
