Description: Ubuntu 24.04.1 LTS
uname -r 6.8.0-45-generic
model name: Intel(R) Core(TM) Ultra 7 155H
cat /etc/apt/sources.list.d/intel-openvino-2024.list
deb https://apt.repos.intel.com/openvino/2024 ubuntu24 main
lspci | grep -i "npu"
0000:00:0b.0 Processing accelerators: Intel Corporation Meteor Lake NPU (rev 04)
modinfo intel_vpu
filename: /lib/modules/6.8.0-45-generic/kernel/drivers/accel/ivpu/intel_vpu.ko.zst
version: 1.0.
license: GPL and additional rights
description: Driver for Intel NPU (Neural Processing Unit)
author: Intel Corporation
cloned intel-npu-acceleration-library from github it gets error out when running cmake.
file(GLOB OpenVINObin ${openvino_SOURCE_DIR}/runtime/lib/intel64/*)
file(COPY ${OpenVINObin} DESTINATION ${CMAKE_LIBRARY_OUTPUT_DIRECTORY})
Any idea, what's causing it or do i need to set any ENVIRONMENT VARIABLES?
-- Setting GCC/Clang specific flags for the entire build
-- OpenVINO library URL: https://storage.openvinotoolkit.org/repositories/openvino/packages/2024.2/linux/l_openvino_toolkit_ubuntu22_2024.2.0.15519.5c0f38f83f6_x86_64.tgz
CMake Warning (dev) at /usr/share/cmake-3.28/Modules/FetchContent.cmake:1331 (message):
The DOWNLOAD_EXTRACT_TIMESTAMP option was not given and policy CMP0135 is
not set. The policy's OLD behavior will be used. When using a URL
download, the timestamps of extracted files should preferably be that of
the time of extraction, otherwise code that depends on the extracted
contents might not be rebuilt if the URL changes. The OLD behavior
preserves the timestamps from the archive instead, but this is usually not
what you want. Update your project to the NEW behavior or specify the
DOWNLOAD_EXTRACT_TIMESTAMP option with a value of true to avoid this
robustness issue.
Call Stack (most recent call first):
CMakeLists.txt:86 (FetchContent_Declare)
This warning is for project developers. Use -Wno-dev to suppress it.
CMake Error at CMakeLists.txt:103 (file):
file COPY given no DESTINATION
if (WIN32)
set (CMAKE_RUNTIME_OUTPUT_DIRECTORY ${CMAKE_LIBRARY_OUTPUT_DIRECTORY})
file(GLOB OpenVINObin ${openvino_SOURCE_DIR}/runtime/bin/intel64/Release/*)
file(COPY ${OpenVINObin} DESTINATION ${CMAKE_LIBRARY_OUTPUT_DIRECTORY}/Release)
file(GLOB TBBlib ${openvino_SOURCE_DIR}/runtime/3rdparty/tbb/bin/*)
file(COPY ${TBBlib} DESTINATION ${CMAKE_LIBRARY_OUTPUT_DIRECTORY}/Release)
else()
endif()
