AI Tools from Intel
Find answers to your toolkit installation, configuration, and get-started questions.
One API Null pointer exception
Ujjayanta
I am trying to run the notebook: https://github.com/IntelPython/daal4py/blob/master/examples/daal4py_data_science.ipynb
I am getting an error here:
d4p_lm = d4p.linear_regression_training(interceptFlag=True)
lm_trained = d4p_lm.compute(reduced_dataset.values, target)
RuntimeError                              Traceback (most recent call last)
<ipython-input-73-3f33ed888e39> in <module>
     24
     25 d4p_lm = d4p.linear_regression_training(interceptFlag=True)
---> 26 lm_trained = d4p_lm.compute(reduced_dataset.values, target)
build\daal4py_cy.pyx in _daal4py.linear_regression_training.compute()
build\daal4py_cy.pyx in _daal4py.linear_regression_training._compute()
RuntimeError: Null pointer in input arguments
 I get this null pointer error in naive bayes and a lot of other examples as well in https://github.com/IntelPython/daal4py/tree/master/examples.
How do I get over these null pointer woes?
RaeesaM_Intel
Hi ,
Thank you for posting in Intel AI Analytics Toolkit Forum.
Can you share the environment details that you used to run the notebook daal4py_data_science.ipynb . Are you using daal4py preinstalled with Intel AI Analytics toolkit environment or separately created a daal4py environment like in https://github.com/IntelPython/daal4py/blob/master/README.md ?
We were able to successfully run the notebook using AI environment. Please refer the below link for creating AI environment and install necessary packages.
https://software.intel.com/content/www/us/en/develop/articles/installing-ai-kit-with-conda.html
Also, please make sure that you have run all the cells before "Training the model " section.
Thanks and Regards ,
Raeesa
Ujjayanta
Hi
I have set up my conda environment using:
conda create -n DAAL4PY python=3.6 impi-devel daal daal-include cython jinja2 numpy clang-tools -c intel -c conda-forge
conda activate DAAL4PY
conda install -c intel daal4py
RaeesaM_Intel
Hi ,
Can you try these steps :
1.      creating a conda environment and setting environment variable
conda create -n DAAL4PY python=3.7 impi-devel daal daal-include cython jinja2 numpy clang-tools -c intel -c conda-forge
export DAALROOT=$CONDA_PREFIX
export MPIROOT=$CONDA_PREFIX
2.      building daal4py
cd <directory-where-setup.py-is-present>
python setup.py build_ext
3.      installing daal4py
python setup.py install
4.      Installing packages if necessary
conda install -c intel/label/oneapibeta daal4py
pip install matplotlib
pip install pandas
5.      Checking the requirements using python shell
Python
>>>import pandas
>>>import matplotlib
>>>import glob
>>>import sys
>>>import daal4py
Are you using a different dataset or the same one used in notebook (data/batch/cycling_dataset.csv) ? Also check whether all the cells before ‘Training the model’ section are running successfully as expected.
Raeesa
Ujjayanta
Hi
What would be the equivalent for the export commands in Windows?
RaeesaM_Intel
Hi ,
You can use SET in windows equivalent to EXPORT in linux.
So the commands will be ,
set DAALROOT=$CONDA_PREFIX
set MPIROOT=$CONDA_PREFIX
We tried running the notebook in linux and it worked fine,will try out in windows and get back to you on the updates.
Raeesa
RaeesaM_Intel
Hi Ujjayanta,
We were able to run the notebook without any errors on windows. Could you please try again with these steps :
1.      Creating a conda environment and setting environment variable
2.      Installing packages if necessary
conda install matplotlib
conda install pandas
Raeesa
RaeesaM_Intel
Has the solution provided helped you? Please let us know if the issue still persists.
RaeesaM_Intel
We haven't got any updates from your side. We are discontinuing monitoring this thread. Please raise a new query if you have any further issues. We would be happy to help you.
Raeesa
