Analyzers
5339 Discussions
Advisor gets stuck while running map
preeth
I am trying to run Memory access pattern in Advisor, previously I have used advisor to run roofline and it was fine.
I ran Advisor using this command to collect map:
./Advisor --collect map --project-dir ../../../map -- /path_to_my_executable
My executable ran fine all test cases passed but advisor gets stuck at loading result.
I tried with different advisor version 2023.2.0 and the latest 2024 one both get stuck at the same point.
I'd really appreciate it if you could help me. Thank you
preeth
It took some time nearly an hour, but I got the results. The results turned out to be empty. Then I ran survey first then map, this time the results made sense. One thing I noticed is memory access information was not available for all loops. Does it only record if the loop runs for more than n times?
Best Regards
preeth
yuzhang3_intel
Could you try with one simple example first? like matrix sample.
$ advisor -collect map -- /home/xxx/intel/vtune/samples/matrix/matrix
I use Advisor 2024.2.1, it can work fine.
preeth
Thanks for the response.
Map works fine, but if only ran map I am unable to see anything in gui.
If I run survey+map I am able to see memory access patterns for certain loops, so is this the case generally? i.e, we need to run survey first then map.
yuzhang3_intel
The user needs to choose the correct analysis perspective depending on the workload type, such as vectorization, roofline, threading, etc. The advisor tool will give steps per perspective. For example, if you want to profile threading below, you can get recommended steps.
For your case, survey + map is necessary; I think the map should rely on the survey report.
preeth
