Analyzers
5295 Discussions
Another problem with Vtune 9.0.016
hex_vulture
Hello.
I have installed Vtune 9.0.016 for Windows. (i have 32 bit XP Windows)
if i tune any exe (vtundemo.exe for example) by qick performance analisis i have error:
Wed Aug 22 15:20:45 2007 MONSTER (Run 1) Setting Sampling CPU mask to 0-3
Wed Aug 22 15:20:45 2007 MONSTER (Run 1) The processor PMU configuration file: pmm.xml
Wed Aug 22 15:20:45 2007 MONSTER (Run 1) Collection for the following event(s) is being performed:
Wed Aug 22 15:20:45 2007 MONSTER (Run 1) CPU_CLK_UNHALTED.CORE, INST_RETIRED.ANY.
Wed Aug 22 15:20:45 2007 ERROR: MONSTER (Run 1) Invalid path (4)
i don't know what path Vtune wants.
please, help.
hex_vulture
and i have installed Vtune for another machine with Pentium 4M CPU.
it works.
but i still need to install Vtune on the previous machine (Core 2 Quad)
and, btw, with threads Profiler i have similar problem.
please, help, i am stuck
David_A_Intel1
HV: don't use the QPA!!
Just use the Sampling wizard and see if it doesn't work better!
hex_vulture
Ihave used theSampling wizard too.
it gives the same result
skosyrev
In my case the reason was cyrillic username, so VTune cannot manage it's own files into Documents and SettingsCyrillicUserName directory.
jluiselvira
Hello1!!
Im dealing with the same issue right now, so, you say that the name was the problem ?, what did you change to solve it ?. Is it a configuration issue ??
Thanks in advance
jluiselvira
Hello again!!!
I already solve it, what I did it is to change an with a e in path name when saving the project. and then Vtune uses the new path in all new projects.
Thanks anyway
Vova
We've encountered similar problem. The solution is to create projects in writable folder (check user rights), and the project path must contain english characters only.
