Analyzers
5307 Discussions
Beta for Linux* 2017 - runsa.options: second, empty, --event-config line
jindrich_k_
when i try to run memory analysis, "the result you are opening does not contain any data".
taking to the command line:
/opt/intel/vtune_amplifier_xe_2017.0.0.457868/bin64/amplxe-cl -collect memory-access -app-working-dir /home/kook/ClionProjects/t2 -- /home/kook/ClionProjects/t2/cppout silent
i get:
amplxe: Error: Option 'event-config' received value from the next argument: '--sample-after-multiplier=1.0', but it seems to be an option. Use '-option=value' declaration form or make sure that value is not missed
the generated runsa.options file looks like this:
-r
/home/kook/intel/amplxe/projects/cccc/r001macc
--target=host
--itt-config=frame
--bandwidth-limits
--data-limit-mb=500
--mrte-type=java
--event-config=CPU_CLK_UNHALTED.CORE:sa=2300000,CPU_CLK_UNHALTED.REF:sa=2300000,INST_RETIRED.ANY:sa=
2300000,BUS_DRDY_CLOCKS.THIS_AGENT:sa=100003,BUS_TRANS_BURST.SELF:sa=200003
--event-config
--event-mux
--mrte-mode=auto
silent
notice the spurious --event-config line. I wasnt able to get rid of it with any switches in the gui.
Dmitry_R_Intel1
Could you please provide the processor name for your system?
jindrich_k_
hi
cat /proc/cpuinfo
processor    : 0
vendor_id    : GenuineIntel
cpu family    : 6
model        : 23
model name    : Pentium(R) Dual-Core CPU       T4500  @ 2.30GHz
stepping    : 10
microcode    : 0xa0b
cpu MHz        : 1200.000
cache size    : 1024 KB
physical id    : 0
siblings    : 2
core id        : 0
cpu cores    : 2
apicid        : 0
initial apicid    : 0
fpu        : yes
fpu_exception    : yes
cpuid level    : 13
wp        : yes
flags        : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx lm constant_tsc arch_perfmon pebs bts rep_good nopl aperfmperf pni dtes64 monitor ds_cpl est tm2 ssse3 cx16 xtpr pdcm xsave lahf_lm dtherm
Dmitry_R_Intel1
The problem described in this thread is specific for old Core 2 processors. If possible please try running analysis on a newer platform - Sandy Bridge based or later. You should not see such issues there.
