Analyzers
5307 Discussions
Binary file of the analysis target cannot be found
Luiz_M_
I cannot run VTune Amplifier both via amplxe-cl and amplxe-gui. Below is the error message if I run via amplxe-cl
I can run via console without any problem and binary is there for sure.
amplxe: Collection started. To stop the collection, either press CTRL-C or enter from another console window: amplxe-cl -r /home/sko/dev/project/r009hs -command stop.
amplxe: Error: Binary file of the analysis target cannot be found. Please check the path or specify another path and try again.
amplxe: Error: [Instrumentation Engine]: /home/sko/dev/project/bin/project_exe : Success
Luiz_M_
Even below amplxe-self-checker.sh fail
sko@d-cyb-sko02:/opt/intel/vtune_amplifier/bin64$ ./amplxe-self-checker.sh
Intel(R) VTune(TM) Amplifier Self Check Utility
Copyright (C) 2009-2017 Intel Corporation. All rights reserved.
Build Number: 551022
Instrumentation based analysis check
Example of analysis types: Hotspots, Concurrency, Locks and Waits
    Collection: Fail
amplxe: Error: [Instrumentation Engine]: /opt/intel/vtune_amplifier_2018.2.0.551022/bin64/sample/matrix/lin_intel64/matrix : Success
Vladimir_R_Intel
could you please make the following checks?
1. try another analysis type like advanced-hotspots and general-exploration
2. try to use: /opt/intel/vtune_amplifier_2018.2.0.551022/bin64/pin -- /bin/ls
3. collect logs for a fail scenario using: export AMPLXE_LOG_LEVEL=TRACE and export AMPLXE_LOG_DIR=<directory_for_logs>
Also please specify the system you're working on,  and send us full output of amplxe-self-checker.sh , a bad result for failed collection and logs collected on the 3rd step.
BR,
Vladimir
Luiz_M_
Hi Vladimir,
Which email address I should send the log file?
Seungpil Ko
Vladimir_R_Intel
you could upload it directly here. What about steps 1 and 2?
BR,
Vladimir
