Analyzers
5341 Discussions
Building Sampling drivers failed, header files not found
MickeJ-IUA
Hi, when building sep drivers compilation fails. Linux Fedora workstation. Console output with errors:
ello@fedora:/opt/intel/oneapi/vtune/2025.4/sepdk/src$ sudo ./build-driver
[sudo] password for ello:
C compiler to use: [ /bin/gcc ]
C compiler version: 15.2.1
Make command to use: [ /bin/make ]
Make version: 4.4.1
Kernel source directory: [ /lib/modules/6.16.7-200.fc42.x86_64/build ]
Kernel version: 6.16.7-200
Cleaning workspaces ...
Done
Building sep driver ...
lwpmudrv.c:30:10: fatal error: lwpmudrv_version.h: No such file or directory
   30 | #include "lwpmudrv_version.h"
compilation terminated.
make[4]: *** [/usr/src/kernels/6.16.7-200.fc42.x86_64/scripts/Makefile.build:287: lwpmudrv.o] Error 1
make[4]: *** Waiting for unfinished jobs....
eventmux.c:38:10: fatal error: lwpmudrv_types.h: No such file or directory
   38 | #include "lwpmudrv_types.h"
make[4]: *** [/usr/src/kernels/6.16.7-200.fc42.x86_64/scripts/Makefile.build:287: eventmux.o] Error 1
cpumon.c:44:10: fatal error: lwpmudrv_types.h: No such file or directory
   44 | #include "lwpmudrv_types.h"
make[4]: *** [/usr/src/kernels/6.16.7-200.fc42.x86_64/scripts/Makefile.build:287: cpumon.o] Error 1
control.c:40:10: fatal error: lwpmudrv_types.h: No such file or directory
   40 | #include "lwpmudrv_types.h"
make[4]: *** [/usr/src/kernels/6.16.7-200.fc42.x86_64/scripts/Makefile.build:287: control.o] Error 1
make[3]: *** [/usr/src/kernels/6.16.7-200.fc42.x86_64/Makefile:2033: .] Error 2
make[2]: *** [/usr/src/kernels/6.16.7-200.fc42.x86_64/Makefile:248: __sub-make] Error 2
make[1]: *** [Makefile:248: __sub-make] Error 2
make: *** [Makefile:234: default] Error 2
Failed to build the drivers
MaitreyeeR
Yeah , I am facing similar issue and it has nothing to do with any files missing it is because the kernel version , you are using the latest Linux Kernel and that's not supported by the driver
jonejames235
The build fails because required header files (lwpmudrv_version.h and lwpmudrv_types.h) are missing. Make sure the SEP driver source is complete and that all dependencies are installed. Often, this happens if the source folder isn’t fully extracted or the build script can’t locate the headers. Verify the source directory and include paths before rebuilding.
MickeJ-IUA
What a bad answer, must be AI...
The installation readme.txt states:
# build the driver:
cd /path/to/sepdk/sources/
./build-driver
There is no "path/to/sepdk/sources/", it is actually "path/to/sepdk/src/"
Your AI slop answer "...the build script can’t locate the headers..." true that.
The "missing" headers is located in "/opt/intel/oneapi/vtune/2025.4/sepdk/src/inc" folder.
The make file complains it can not find headers located in the /inc  subfolder. What should i do, customize the Intels make file? Is it not better that Intel ships a makefile and readme.txt that is correct and works?
MaitreyeeR
