Analyzers
5341 Discussions
Call Count column does not appear
L_K_
Hi.  I'm running Advanced Hotspots analysis with Hot Spots, call counts, stacks and context switches checked  However, when I look at the results, I don't see Call Count column.  I have Show All columns checked and scrolling to the right or left does not reveal a column.  Any idea?  Thanks.
Peter_W_Intel
If you already did "Show All Columns", it might be due to vtss plus driver was not enabled.
Do you work on Linux*? I remember that the feature needs Linux kernel version 2.6.32 or above.
Check - "lsmod | grep vtsspp" if that driver was loaded.
Another thing is - are your sure if your hot function calls were low number, this might cause "call count" column invisible. You may build a simple example which calls hot functions frequently from a loop, then verify.
L_K_
This is VMware 10, Windows 7 environment.  Thanks.
Bernard
Valued Contributor I
Try to run from elevated cmd driverquery -v and look for vtss.sys driver entry. Pay attention to started and running info.
Peter_W_Intel
@ L K
Thanks for info. However I wonder that only operation system on VMWare Fusion* 5 is supported to run hardware event-based sampling - as I know you ran advanced-hotspots, but I saw your all CPI values are zero!!! Can you verify this issue in native operation system?
Thanks, Peter
Bernard
@L K
What is your host OS?
L_K_
Host OS - Windows 7, 64 bit
Guest, VMWare 10, Windows 7, 32 bit
vtss is running
Thank you.
Bernard
Did you try to check functions call count while profiling your code on the Host machine?
Peter_W_Intel
In order to verify if this is problematical result (I saw that CPI is zero in columns.png), you can use command line to display interest of data from  the report by using:
amplxe-cl -report hotspots; // which should display "call count" column, if you enabled it during data collecting.
amplxe-cl -report summary; // verify CPI value in this report, it it zero? It doesn't make sense.
Bernard
@Peter
Is there a possibility to receive or redirect VTune output to comsole window only without loading UI? I was thinking about the possibility of failure related to some column CPI UI handler.
Bernard
>>>Is there a possibility to receive or redirect VTune output to comsole window only without loading UI>>>
Of course as a diagnostic option.
L_K_
I ran command option followed by > summary.txt and got the output ( or most of it? ) to the file. See attached.  Does VTune support advanced hotspots on VMware Workstation ( Win 7 guest & Host )?  It would take me a bit to set it up on non-VM environment to see if I get correct results ( even if I do - my expectation was that I could run this on VM as I used to with an old version of VTune - I'm aware of changes ).  I can try running sample and analyzing it on the same VM & see what I get...
here are hotspot columns ( 3 ):
Function        Module                  CPU Time:Self
KiFastSystemCallRet        ntdll.dll                       4.152
func@0x1006b351        MSO.DLL                         0.984
func@0x10008f53        OLMAPI32.DLL                    0.980
func@0x101608d1        MSO.DLL                         0.802
func@0x1015b0bc        MSO.DLL                         0.241
func@0x100048c0        MSPST32.DLL                     0.204
CUserThread::SendRequest        mydll.dll                     0.186
Summary is attached.
Bernard
Looks like most of the CPU time is spent in kernel-to-user mode stub function.  Does your code frequently call into kernel mode?
L_K_
The application being profiled is Microsoft Outlook so that's expected.  It's not the point, however.  We are trying to figure out where did the Call counts go...Peter was looking for a meaningful  value for CPI as well.
Peter_W_Intel
They are unexpected results.
Event summary
Hardware Event Type               Hardware Event Count:Self  Hardware Event Sample Count:Self  Events Per Sample
INST_RETIRED.ANY                                          0                                 0  2700000
CPU_CLK_UNHALTED.THREAD                                   0                                 0  2700000
CPU_CLK_UNHALTED.REF_TSC                        46382069573                             23191  2000003
No sample are collected for INST_RETIRED.ANY and CPU_CLK_UNHALTED.THREAD, so there is no CPI value.
And, no "call count" column in hotspots report.
No. You have to work on native operation system.
You can run basic-hotspots, concurrency, and locksandwaits on VMware workstation with Win 7, because they are user-mode sampling and no PMU resource access.
L_K_
Already then.  Once I get a chance I'll try without virtualization.
Bernard
I was under assumption that it was your application.
