Analyzers
5316 Discussions
Can I collect data in multiple mode?
Bak__Jiseong
I'm interested in performance related to vectorization and memory access of my application, and I'm quite newbie in VTune.
I use two commands,
amplxe-cl -collect hpc-performance
amplxe-cl -collect memory-access
And, the result of each (r@@@hpc, r@@@macc directories are made) has its detailed data that the other doesn't have. But I want both. So, I'm wondering if I can get the result of both of them with one command.
Dmitry_P_Intel1
HPC Performance analysis also contains memory metrics. What metrics are missed from memory-access in HPC Performance for you?
You cannot run both analysis types simultaneously but it might be possible to create a custom analysis type that will contain events for both type of information.
Thanks & Regards, Dmitry
