Analyzers
Can't see the source code
titan_wang
Hi All,
I have a problem when reading sampling result in souce view.
After run an activity, I can see most of the source code in souce window.
But when I double-click on some functions or souce files, I got this message:
"WARNING: Source view opens one continuous code address range, functions that are out of this range will not have disassembly or events.
Tip: Drill down directly to these functions to get their full information."
And the source window is BLANK!
After I change somethingin my source code, this problem might gone.
I checked my colleagues' VTune, They also get this message, but the souce view is ok.
My two platforms both have this problem, The version is 6.1.0.8034 and 7.0.10246 and re-install doesn't help at all. :(
Please help me if you experienced this before.
Titan
titan_wang
Dear all, I find the root cause of this problem. If I dock the "output window" to the bottom, this problem is gone. Just for your reference. Titan
