Analyzers
5285 Discussions
Cannot generate hotspots report in source-line level
bofang_2012
Hi all,
I was using vtune to profile my C++ application on Linux. I can only use the command-line interface. I choose hotspots for my analysis but I can only get function level report. I tried to add -group-by source-line in report command but what I got was:
Executing actions 75 % Generating a report
Source File Source Line Module Source File Path CPU Time
[Unknown source file] [Unknown] test [Unknown] 0.130
It seems that there is a lack of source file information. I did use the debug version of the program. Is there any other info I need to provide to vtune? Thanks in advance.
Bo
Peter_W_Intel
You have to use option "/Zi" and "/DEBUG" to build on Windows, use "-g" option on Linux.
I have no problem to use "-group-by source-line": I ran program under directory where it has executable and source
(You may add "-search-dir all:rp=/home/your-exe-path" when data collecting?)
# source /opt/intel/vtune_amplifier_xe_2011/amplxe-vars.sh
Copyright (C) 2009-2012 Intel Corporation. All rights reserved.
Intel VTune Amplifier XE 2011 (build 221625)
# amplxe-cl -collect hotspots -- ./primes.icc
Determining primes from 1 - 100000
Found 9592 primes
Using result path `/home/peter/problem_report/r003hs'
Summary
Elapsed Time: 0.967
CPU Time: 2.370
Executing actions 100 % done
# amplxe-cl -report hotspots -group-by source-line -r r003hs
primes.cpp 391 primes.icc /home/peter/problem_report/primes.cpp 2.360
primes.cpp 395 primes.icc /home/peter/problem_report/primes.cpp 0.010
bofang_2012
Hi Peter,
Thank you for your reply. Actually I did use -g for compilation. But I realized that there might be problems here because I cannot even look at some of my source files in gdb ( for example, for one particular .h file i cannot see the corresponding .cpp file in gdb). That may cause the problem in vtune.
Btw, do I have to use intel compiler? From your example I see that you are using intel compiler right?
Bo
Peter_W_Intel
Bo,
Thanks for the update, this is NOT the VTune issue.
VTune Amplifier XE doesn't rely on compiler type, that means, the tool supports standard binary/symbolformat - i.e. PE2 , DWARF, etc.
However if you choose Intel compiler - which provides more advanced options to build executable for performance gain.
Regards, Peter
