Analyzers
5270 Discussions
Cannot locate debugging symbols for file `/tmp/amplxe-tmp-lab/xxxxx/
Srivatsan_K_Intel
I am trying to profile an application using the remote analysis workflow as mentioned in this link.
https://software.intel.com/en-us/node/496398#46F7A60C-C2A4-4EEA-9460-BC33B892DA8F
When i try to the run the profiler using GUI as well as command line, i am getting these warning messages:
amplxe: Using result path `/home/xxxx/vtune_trial/xxxxxx/r002hs'
amplxe: Executing actions 16 % Resolving information for `bash'
amplxe: Warning: Cannot locate debugging symbols for file `/tmp/amplxe-tmp-xxxxx/modules.ssh_xxxx@xxxxxxxxxxxxxx/bash/d79a947d06958e7826d15a5c78bfaa05/bash'.
amplxe: Executing actions 17 % Resolving information for `ls'
amplxe: Warning: Cannot locate debugging symbols for file `/tmp/amplxe-tmp-xxxx/modules.ssh_xxxx@xxx-xxxxxxxxxxxxxxx/ls/fa97c59cc414e42d4e0e853ddf5b4745/ls'.
amplxe: Executing actions 17 % Resolving information for `sed'
amplxe: Warning: Cannot locate debugging symbols for file `/tmp/amplxe-tmp-xxxxxxxxx/modules.ssh_xxx@xxxxxxxxxxxxxxxxxxxxxxxxxx/sed/89ecfdcf755d11e6f73fbb7fed9248d0/sed'.
amplxe: Executing actions 50 % Generating a report
Can anyone tell me what is going on here? The analysis report doesn't have much hotspot details.
Sri
Peter_W_Intel
There are no debugging info for utilities bash, ls, sed - they have no symbol info in binaries.
You can ignore these warning message...you need to pay attention on hotspots which located on your modules. If reported your modules have no debugging info, you need to check if you added "-g" to build applications? then added option "-search-dir=$dir1" ($dir1 is the location of your binaries in host) to collect performance data.
