Analyzers
Change Problem State outside GUI?
Frankie_F_1
I could change problem states from New to Deferred(or others) with the Inspector GUI. Is it possible to do that programmatically with a client library? That would allow, for example, multiple developers to update issue states issue management with web interface.
Frankie
Peter_W_Intel
I cannot find any way to change the problems' state outside GUI, I mean in command line.
The possible workaround is - initial result directory can be copied to multiple developers. Everyone can investigate the their problems and changes their problems' state in copied result directories, they can merge their problems' state to initial result directory. For example,
inspxe-cl -merge-states ./new-result-devloper1 -result-dir ./init-result
inspxe-cl -merge-states ./new-result-devloper2 -result-dir ./init-result
Frankie_F_1
Hi Peter,
Thanks for the suggestion. Does it require an active license in order to update the 'problem state' with Inspector GUI?
Frankie
Peter_W_Intel
Frankie F. wrote:
Hi Peter,
Frankie
Sure...every developer should have active license to change problems' state, then merge new state to result (state) to original result directory (baseline)
So far we don't support to edit state in result directory:-)
Frankie_F_1
I see. Thanks.
Frankie
