Analyzers
Code coverage
speri
I am trying to analyze if intel vtune can be used as code coverage tool, with % of lines,functions,api's.
I can get most of these information from the product, but i don't know if there is easy way of calculating numbers.
I am comparing this with other code coverage tools like Livecoverage,purecoverage,Bullseye.
i appreciate all your inputs.
Daniel_B_Intel2
as far as I know currently there is no code coverage functionality in VTune.
But Intel compilers have, please refer it's manual.
-Daniel
hegdehp
The latest version of Intel compiler can be used as a code coverage tool.
1. Compile the code using -O2 -prof_genx -prof_dir ~home/prof/
2. Instrument the execution
3. run codecov in ~home/prof/
The output should be CODE_COVERAGE.HTML and a directory Code_Coverage.
-Hrishi
-Hrishi
