Analyzers
5342 Discussions
Collect arguments for a certain function call
Po-yen_C_Intel
I am analyze my workload which has a very hot function. I wonder if I can use Vtune to report what arguments are passed into this function? For example, if I have a function func() take one character as an input,
argument "a" : 10 times
argument "b" : 100 times
argument "c": 50 times
I try to google the answer but there seems to be no such solution, no matter in Vtune or other tools.The problem is I want to do this without changing the source code.
Thank you very much
Ekaterina_L_Intel
VTune doesn't provide such capabilities.
It sounds more like an automated debugging which can be done via GDB scripts. See examples here: http://stackoverflow.com/questions/10748501/what-are-the-best-ways-to-automate-a-gdb-debugging-session
A very simple gdb script file reporting all func invocations with arguments might look as below:
set width 0
set height 0
set verbose off
start  # runs to main, so shared libraries are loaded
break func
commands 2
  cont
end
run
Then it can be run via GDB as:
>gdb --batch --command=./script --args <your workload>
Then you can grep -c the output to count number of particular argument values.
Regards, Katya
Ekaterina_L_Intel
set width 0
set height 0
set verbose off
break func
commands 2
  cont
end
run
Regards, Katya
Po-yen_C_Intel
Thank you Ekaterina!
I am not too familiar with GDB so it took me a while to write and debug my GDB script. It works for me now.
Thanks!
