FORMATEI UM NOTEBOOK POSISITO Q432A MAS NÃO CONSIGO INSTALAR OS DRIVERS DE AUDIO. JA TENTEI TODAS FORMAS E DICAS, BAIXEI O PACOTE COMPLETO DA POSITIVO E MESMO APÓS A INSTALAÇÃO O SOM NÃO FUNCIONA. NO GERENCIADOR DE DISPOSITIVOS DIZ QUE O ESTÁ FUNCIONANDO CORRETAMENTE. O PROBLEMA É SOMENTE COM O SOM, QUE NÃO FUNCIONA.
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
[CoPilot is a virus]
