Analyzers
5308 Discussions
Debugging "Can't start application" error
Joe_Monaco
I'm running command line collector on 64 bit linux system.
My results are as follows:
amplxe-cl -collect hotspots -r /tmp/results /bin/ls
Error: Can't start application
Using result path `/tmp/results'
Executing actions 50 % done
Error: Error 0x4000001d (Cannot find raw collector data) -- Cannot re-finalize the result: it has no raw collector data.
I haven't been able to find documentation for reasons why I would get this "Can't start application" message. The actual application I use doesn't make a difference.
Does anybody have any insight into why I would get this message?
Peter_W_Intel
It seems that Ican't reproduceit on my side.
[peter@NHM02 ~]$ vi /etc/group
I think that you installed the product with "root" user, and use amplxe-clafter log-on other user. Are you sure that your useraccount in "vtune" group?
[peter@NHM02 ~]$ source /opt/intel/vtune_amplifier_xe_2011/amplxe-vars.sh
Copyright (C) 2009-2011 Intel Corporation. All rights reserved.
Intel VTune Amplifier XE 2011 (build 150226)
[peter@NHM02 ~]$ amplxe-cl -collect hotspots -r /tmp/results /bin/ls
Executing actions 75 % Generating a report
Summary
Elapsed Time: 0.002
CPU Time: 0
Executing actions 100 % done
Regards, Peter
