Analyzers
5272 Discussions
Determine CPU utilization(%) from CPU time given by VTune
Rupinder__V_
Currently i am working with Vtune. I am trying to calculate CPU% utilization give the "CPU seconds used" and the elapsed time.
Is this write :  CPU% = cpu time(secs) / elapsed time. ?
e.g. in 2 core machine
cpu sec =5.6 , elapsed time = 8.4
cpu% = 5.6 / 8.4 .
Also how to map cpu time and utilization in multicore environment.
rupinder
Peter_W_Intel
No. They are total differenr concepts. Let me explain more -
1. Elapsed time = end time - start time (profiling)
2. CPU time of function : captured samples of function * interval . For example, if you got 100 samples in f1(), and interval is 10ms as default. So CPU time of f1() = 100 * 10ms = 1s
3. CPU Utilization : time period from function's entry & exit, it lasts 2s. As I said f1() took 1s in one core, so CPU utilization is 50% (probably instruction was suspended, IO waits, etc)
4. Same situation for multicore, if the system is 2 cores, Full utilization is 200%, follow the point 3, meanwhile if
a) Other function ran 2s on another core, so CPU utilization is 3s / 2s = 150%
b) Other function ran 1s on another core, so CPU utilization is 2s / 2s = 100%
c) No other function run on another core, so CPU utilization is 1s / 2s = 50%.
Please observe timeline report to view these data.
Bernard
Valued Contributor I
>>>3. CPU Utilization : time period from function's entry & exit, it lasts 2s. As I said f1() took 1s in one core, so CPU utilization is 50% (probably instruction was suspended, IO waits>>>, etc)
I would like to know what is time scale granularity of CPU utilization measurement?What happens for example when current executting function's thread is swapped out and other thread is scheduled to run?
