Analyzers
5342 Discussions
Difference between Basic and Advanced hotspots
Kavran__Peter
I am experiencing a difference between the basic and advanced hotspots results, adn I cannot explain that.
I would expect similar results. The same code, same data were used for both.
Please, see attached picture.
Thanks for your help,
Peter
Dmitry_P_Intel1
Hello Peter,
Did you collect advanced hotspots with stacks?
If no - could you please do this and compare? The point is that VTune might not classify spins/overheads w/o stacks in the full way so the metrics based on this differ.
Thank you, Regards, Dmitry
