Analyzers
5281 Discussions
Does VTune support the "Lunar Lake" GPU profiling? - Intel Core Ultra 7 268V
JIANHUI_D_Intel
Hi Support team:
  I used the VTune (Windows) for "Lunar Lake" GPU profiling, but it does not provide any data about GPU. It's good for MTL GPU Profiling.
 Both latest VTune are tried:
  • Intel_VTune_Profiler_2024.2.0_nda.zip
  • Intel_VTune_Profiler_2024.1.0_internal.zip
If not, Any support plan?
yuzhang3_intel
Please provide the OS version, thanks.
JIANHUI_D_Intel
Windows Version Microsoft Windows 11 Enterprise Edition (x64), Version 23H2, Build 22631.3737
DirectX Version 12.0
yuzhang3_intel
Please try with the coming 2024.2.1 release, the current VTune release doesn't support LNL for GPU profiling.
JIANHUI_D_Intel
JIANHUI_D_Intel
May I ask the estimated timeline of 2024.2.1 release?
I'm really looking forward to it!
yuzhang3_intel
I don't know the accurate delivery date, but it should be released in two weeks. Actually, the pre-build is ready. It's just in the delivery process.
yuzhang3_intel
VTune 2024.2.1 has been released, you can try it.
JIANHUI_D_Intel
Thanks for letting me know. I'll try out the new release.
JIANHUI_D_Intel
Confirmed  VTune 2024.2.1 captures GPU metrics on LNL. Thank you the supporting.
JIANHUI_D_Intel
But unlike the MTL results, the `Packet Type` Grouping is empty, is it expected?
yuzhang3_intel
Did you run which analysis type?
JIANHUI_D_Intel
It's GPU Compute/Media Hotstpots (preview).
Attached the MTL vs LNL screenshot for this issue.
yuzhang3_intel
Did you profile system using GPU hotspots analysis type? and if the workloads are the same when profiling on MTL and LNL?
JIANHUI_D_Intel
Yes. It's system profiling not launch application, for both MTL/LNL.
yuzhang3_intel
Not sure if this is one issue, let me check and then give you an update. Thanks.
JIANHUI_D_Intel
This feature is quite helpful in GPU computing profiling on previous MTL and so on.
For example, if we captured 10s vtune result, but we filter/zoom the 2s~5s and get the perf stat of this period of time.
Hopefully, this feature will be back soon for LNL.
yuzhang3_intel
Thanks for the clarification, I will escalate the issue to engineering team and feedback later.
yuzhang3_intel
In addition, can you share your VTune data here?
JIANHUI_D_Intel
Sure.
Do you mind to share your mail, that i can share by Teams? Or ping me jianhui.j.dai@intel.com
yuzhang3_intel
Sure, I have shared one link with you for uploading your data.
