Analyzers
5341 Discussions
ERROR: incompatible kernel!
nicolas_cadio
I use a debian 5.04. Before I used the kernel 2.6.26-2 but I had this error ([ERROR] unable to open SELI interface) so I downgrade to the kernel 2.6.26-1. I reinstall Vtune and I rebuild a driver for this kernel.
This is the output of the comman ./build-driver :
Options in brackets "[ ... ]" indicate default values
that will be used when only the ENTER key is pressed.
C compiler to use: [ /usr/bin/gcc ] gcc-4.3
Make command to use: [ /usr/bin/make ]
Kernel source directory: [ /lib/modules/2.6.26-1-amd64/build ]
checking for template makefile ... Makefile.in
checking architecture ... x86_64
checking for kernel headers ... /lib/modules/2.6.26-1-amd64/build/include
checking if C compiler is working ... yes
checking if C compiler supports anonymous structs and unions ... yes
checking if C compiler supports large frame sizes ... no
checking kernel version ... 2.6.26-1-amd64
checking whether kernel modules can be built ... yes
checking if UP or SMP ... SMP
checking if LBRs are supported ... yes
checking if 32-bit ioctls are supported ... no
checking if mmap_*_read is supported ... no
checking if mm.h is available ... yes
checking if for_each_process is exported ... yes
checking if task_struct has a parent field... yes
checking which type of remap to use ... remap_pfn_range
checking if read_trylock is available ... yes
checking if write_trylock is available ... yes
checking if set_user_nice is available ... yes
checking if msecs_to_jiffies is available ... yes
checking for kernel symbol file ... /boot/System.map-2.6.26-1-amd64
checking if kernel exports CPU frequency ... yes
checking if kernel profile hooks exist ... yes
checking if tasklist_lock is exported ... no
checking if on_each_cpu has retry parameter ... yes
checking how to access task information ...find_task_by_pid
rm -f vtune.o random.o pcg.o per_cpu_buffer.o os_dependent.o user_status.o plugin.o utility.o vtune.o random.o pcg.o per_cpu_buffer.o os_dependent.o user_status.o plugin.o utility.o vtlib32_64.o vtxsys32_64.o apic32_64.o vtlibcommon32.o profile_hooks.o .*.cmd built-in.o .*.o.d vtune_drv.o vtune_drv.ko vtune_drv.mod.* Module*.symvers Module*.markers modules.order
rm -rf .tmp_versions
rm -f vtune_drv-x32_64-2.6.26-1-amd64smp.ko
/usr/bin/make "V=0" -C /lib/modules/2.6.26-1-amd64/build SUBDIRS=/opt/intel/vtune/vdk/src modules
make[1]: Entering directory `/usr/src/linux-headers-2.6.26-1-amd64'
CC /opt/intel/vtune/vdk/src/vtune.o
CC /opt/intel/vtune/vdk/src/random.o
CC /opt/intel/vtune/vdk/src/pcg.o
CC /opt/intel/vtune/vdk/src/per_cpu_buffer.o
CC /opt/intel/vtune/vdk/src/os_dependent.o
CC /opt/intel/vtune/vdk/src/user_status.o
CC /opt/intel/vtune/vdk/src/plugin.o
CC /opt/intel/vtune/vdk/src/utility.o
CC /opt/intel/vtune/vdk/src/vtlib32_64.o
AS /opt/intel/vtune/vdk/src/vtxsys32_64.o
CC /opt/intel/vtune/vdk/src/apic32_64.o
CC /opt/intel/vtune/vdk/src/vtlibcommon32.o
CC /opt/intel/vtune/vdk/src/profile_hooks.o
LD /opt/intel/vtune/vdk/src/vtune_drv.o
Building modules, stage 2.
MODPOST 1 modules
CC /opt/intel/vtune/vdk/src/vtune_drv.mod.o
LD /opt/intel/vtune/vdk/src/vtune_drv.ko
make[1]: Leaving directory `/usr/src/linux-headers-2.6.26-1-amd64'
Renamed vtune_drv.ko to vtune_drv-x32_64-2.6.26-1-amd64smp.ko .
Directory to install sampling driver: [ /opt/intel/vtune/vdk/src ] ..
Installed sampling driver to /opt/intel/vtune/vdk/vtune_drv-x32_64-2.6.26-1-amd64smp.ko .
When I type the command ./insmod-vtune, there is this error :
The kernel that sampling driver vtune_drv-x32_64-2.6.26-1-amd64smp.ko
was built against does not match kernel /boot/vmlinuz-2.6.26-1-amd64 .
Please see driver README for instructions on building a driver
for your kernel.
I don't understand why the command insmod-vtune return ths error, the driver seems good.
If any body have clue what is going on please help.
regards, nico
nicolas_cadio
I solve my problem, I has not use the same compiler for the kernel and the driver.
I has not read the README of /vdk/src/ :
Requirements for building the VTune Performance Analyzer sampling driver:
- a Linux* system with an IA32 processor (with or without Intel Extended
Memory 64 Technology) or with an Itanium processor
- system must have GCC compiler version 2.96 or higher installed
- same compiler used to build the kernel should be used to build the driver
- system must have GLIBC version 2.2.2 or higher installed
- system must have development environment (e.g., glibc-devel*.rpm) installed
