Analyzers
5315 Discussions
Error No navigation target registed for this context
Tomer_W_Intel
While trying to run the Vtune with EXE file (genereted by msdev) I get the error message above.
after the run ends , the call graph loook rigth , but I can't find my application function in the sampeling result
Message Edited by tomer.weiner@intel.com on 05-17-2004 12:37 AM
David_A_Intel1
This is typically a problem with the product components getting registered correctly. Have you ever successfully collected call graph data and viewed it?
If the data is displayed, but you don't see your application, ensure that you have full symbol information generated for the application and that the analyzer has located it. Open the configuration dialog for the call graph activity and find your application in the list of modules. Then, scroll, if necessary, to the "Debug Info" column. Does it havea "Yes" value for your module?
If you are still unsuccessful, please submit an issue at http://premier.intel.com
