Analyzers
Error: SYSCALL_INSPECTOR
siwei
I tried to run an application which built by VS 2019 under intel SDE. but SDE gave me this message. My OS is win10
E: SYSCALL_INSPECTOR: The NTDLL!NtContinue function jumps out of NTDLL, at 0x77c4225c. It may be hooked by a PIN-incompatible software installed on the system
A: Source\pin\base_w\ipc_server_windows.cpp: LEVEL_BASE::StartServer: 2216: assertion failed: res == TRUE
NO STACK TRACE AVAILABLE
what causes that?
thanks
Best regards
