Analyzers
5272 Discussions
Error in vtune profiler hotspots(Hardware event-based sampling)
Impossilbe
When testing the program on hardware event-based sampling, I got an error message
Is there any solution to solve these errors? Thanks in advance.
Below is my device information :
Ubuntu 20.04.6 LTS
Intel(R) Core(TM) i7-7700 CPU @ 3.60GHz
JaideepK_Intel
Thank you for posting in intel communities.
Could you please follow the below steps?
  1. Run terminal as root/sudo user.
  2. Check whether all the drivers are loaded properly or not with the below command.
sudo <oneapi_install_directory>/vtune/latest/sepdk/src/insmod-sep -q
example:
/opt/intel/oneapi/vtune/latest/sepdk/src/insmod-sep -q
If all the drivers are not loaded properly, please run the below command:
sudo <oneapi_install_directory>/vtune/latest/sepdk/src/build-driver
(eg:/opt/intel/oneapi/vtune/latest/sepdk/src/build-driver)
In order to verify all the analyses are working fine, we need to run the self-check file:
sh <oneapi_install_directory>/vtune/latest/bin64/vtune-self-checker.sh
(eg: sh /opt/intel/oneapi/vtune/latest/bin64/vtune-self-checker.sh)
      3. Please let us know you are getting same error with default matrix sample (loaction: /opt/intel/oneapi/vtune/latest/samples/en/C++/matrix/matrix)
      4. If everything works fine, please share a sample reproducer (a replica of your sample) so we can debug further.
Jaideep
JaideepK_Intel
I hope you are doing well.
Could you please share the details that are mentioned above?
Jaideep
JaideepK_Intel
Jaideep
JaideepK_Intel
We have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
Jaideep
