Analyzers
5294 Discussions
Error in vtune2023.2.0 command line tool
Hannah_zhen
I install oneapi base toolkit with vtune2023.2.0 command line tool
However, when I run the command with user: vtune -collect hotspots -result-dir <PATH> -quiet ./<EXE>, the warning:
the report is able to shows in yhe CLI.
But when I open the .vtune file in GUI with vtune 2021.2.1 in win:
Besides, I try to use GPUhotspots
Is there any solution to solve these errors? Thanks in advance.
Below is my device information :
My environment is ubuntu22.04 with 6.2.0-36-generic and the processor is i5-1340P.
DiyaN_Intel
Hi ,
Thanks for posting in Intel communities.
As we can see you have created the report in Vtune 2023.2.0 version in linux environment and opening the report in Vtune 2021.2.1 GUI version in windows which is not possible due to different versions of Intel Vtune.
Please try to update the Vtune GUI in windows to 2023.2.0 and open the results and check if it is working.
If it has resolved your issue, make sure to accept this as a solution.
This would help others with similar issue. Thank you!
Diya
DiyaN_Intel
Hi ,
Diya
DiyaN_Intel
Thanks for accepting our solution.
Glad to know that your issue is resolved.
If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks and Regards,
Diya
