Analyzers
5340 Discussions
Error while loading openmp program in Vtune
jdbaba
Hi All,
I am trying to open the openmp compiled executable code into vtune. I am using Intel compiler and vtune in linux.
The error that I got while loading the file is "error while loading shared libraries: libiomp5.so : cannot open shared object file: No such file or directory"
However, if I try to load the program compiled without openmp then I can load the program on vtune. Why is it behaving so strange ? If I run the program along, then it will run.Do I need to set any environmental variable to load the openmp compiled program ?
Thank you so much.
Jdbaba
Peter_W_Intel
Yes. You should set compiler environment variables in the console where VTune runs, see topic 364566.
