Analyzers
5319 Discussions
Export Results in other types (e.g. csv, xml)
Teodora_C_
I see there is the possibility to export result but only with the extension .inspxez
Is it possible to export results in other types like csv or xml to have the chance to parse the result?
Peter_W_Intel
If you want to export result to text, cvs, xml format file - please use result directory. For example -
>inspxe-cl -R problems -format=text -verbose -r r006mi2
You can replace "text" with "csv" or "xml", and use "> file" to generate file.
