Analyzers
5323 Discussions
Export data from timeline
CHEEHOO_K_Intel
I need the data (Memory bandwidth, CPU analysis, etc.) in time series exported into a readable format such as .csv file.
How can I do that?
Dmitry_R_Intel1
It is possible to get timeline data in command line using 'time' report. To do that you first need to enable this report by defining following environment variable:
AMPLXE_EXPERIMENTAL=time-cl
Then query data you need. E.g. the following command will give you cpu utilization:
vtune -r <vtune_result_dir> -R time -r-k column_by=CPUTime -format=csv -csv-delimiter=semicolon
You can open the time report file located here: <vtune_install_dir>/config/report/experimental.time-cl/time.tmpl and it look for comments at the beginning with more command line examples how to get various kind of timeline data through it, including DRAM bandwidth.
ArunJ_Intel
Hi KOK, CHEE HOO,
Thanks for reaching out to us. If your requirement is to convert the collected vtune report to a readable form like csv please use  -report-output flag of vtune. Pleas find below an example below which converts a hotspot report to csv format.
vtune -R hotspots  -r r002hs -report-output MyReport.csv -format csv -csv-delimiter tab
Arun Jose
xinyingw
Dear KOK, CHEE HOO,
I also need to export timeline data from Vtune just as this psot( community.intel.com/t5/Analyzers/Export-data-from-timeline/m-p/1170493#M18131).  For example, the CPU usage at time 0s, 1s, 2s, 3s..., could you help me please?
CHEEHOO_K_Intel
Hi, thanks for reply.
I know there is a report option in the CLI, but the reports cannot give me the data I need.
I need the time-series data used to plot the timeline pane.
For example, the cpu utilization at time 0s, 1s, 2s, 3s...
Is it possible?
xinyingw
Did you get the timeline data from Vtune? Could you kindly share the command? I also need to analyze my cpu usage. Thank you in advance
ArunJ_Intel
Hey ,
We are forwarding your case to the concerned team. They will get back to you soon.
Arun Jose
CHEEHOO_K_Intel
Jose, Arun (Intel) wrote:
Hey ,
Arun Jose
Thank you very much, appreciate that!
James_T_Intel
I apologize for the delayed response. I have entered this as a feature request for VTune.
Dmitry_R_Intel1
James_T_Intel
This is in our tracking system as a feature request. Additionally, a workaround has been provided. I am closing this case for Intel support. All future replies on this thread will be considered community only.
