Analyzers
5341 Discussions
Extracting call sequence info with VTune
emadshihab
Hi there,
Is there any way of extracting the call sequence info of an application with VTune or even PTU?
I mean if I code something like this:
main(){
f1();
f2();
versus
main(){
f2();
f1();
how can I get a call graph or something that can tell the difference. Is this even possible with VTune or PTU?
Emad
luweichao-2004
I
Nicolae_P_Intel
I just came across your post. It may be too late but I will still vebture to answer:
in PTU you have the statistical callgraph - sampling the call stack at specified intervals - intrusion level very low
or the callgraph in vTune which will give the exact picture but the intrusion level is way higher as for the PTU statistical callgraph.
Hope this helps.
David_A_Intel1
The short answer is, no. Both tools build a "call tree" and do not maintain order of calls. You can "drill down" to the source code and view the order there.
