Analyzers
5315 Discussions
Failed to Build Sampling Driver with 5.10.3 kernel on Ubuntu 20.04.2 LTS
vtan
Good day,
I am having problem compiling Sampling Driver with 5.10.3 kernel:
-------------------- Building pax driver --------------------
make[1]: Entering directory '/opt/intel/oneapi/vtune/2021.1.1/sepdk/src/pax'
/bin/make -C /lib/modules/5.10.3-051003-generic/build M=/opt/intel/oneapi/vtune/2021.1.1/sepdk/src/pax LDDINCDIR=/opt/intel/oneapi/vtune/2021.1.1/sepdk/src/pax/../../include LDDINCDIR1=/opt/intel/oneapi/vtune/2021.1.1/sepdk/src/pax/../inc modules PWD=/opt/intel/oneapi/vtune/2021.1.1/sepdk/src/pax -j4
make[2]: Entering directory '/usr/src/linux-headers-5.10.3-051003-generic'
  CC [M]  /opt/intel/oneapi/vtune/2021.1.1/sepdk/src/pax/pax.o
/opt/intel/oneapi/vtune/2021.1.1/sepdk/src/pax/pax.c: In function ‘pax_Disable_NMIWatchdog’:
/opt/intel/oneapi/vtune/2021.1.1/sepdk/src/pax/pax.c:186:22: error: implicit declaration of function ‘get_fs’; did you mean ‘sget_fc’? [-Werror=implicit-function-declaration]
  186 |             old_fs = get_fs();
      |                      sget_fc
/opt/intel/oneapi/vtune/2021.1.1/sepdk/src/pax/pax.c:186:22: error: incompatible types when assigning to type ‘mm_segment_t’ {aka ‘struct <anonymous>’} from type ‘int’
/opt/intel/oneapi/vtune/2021.1.1/sepdk/src/pax/pax.c:187:13: error: implicit declaration of function ‘set_fs’; did you mean ‘sget_fc’? [-Werror=implicit-function-declaration]
  187 |             set_fs(KERNEL_DS);
      |             sget_fc
/opt/intel/oneapi/vtune/2021.1.1/sepdk/src/pax/pax.c:187:20: error: ‘KERNEL_DS’ undeclared (first use in this function); did you mean ‘KERNFS_NS’?
      |                    KERNFS_NS
/opt/intel/oneapi/vtune/2021.1.1/sepdk/src/pax/pax.c:187:20: note: each undeclared identifier is reported only once for each function it appears in
/opt/intel/oneapi/vtune/2021.1.1/sepdk/src/pax/pax.c: In function ‘pax_Enable_NMIWatchdog’:
/opt/intel/oneapi/vtune/2021.1.1/sepdk/src/pax/pax.c:282:18: error: incompatible types when assigning to type ‘mm_segment_t’ {aka ‘struct <anonymous>’} from type ‘int’
  282 |         old_fs = get_fs();
/opt/intel/oneapi/vtune/2021.1.1/sepdk/src/pax/pax.c:283:16: error: ‘KERNEL_DS’ undeclared (first use in this function); did you mean ‘KERNFS_NS’?
  283 |         set_fs(KERNEL_DS);
      |                KERNFS_NS
cc1: some warnings being treated as errors
make[3]: *** [scripts/Makefile.build:279: /opt/intel/oneapi/vtune/2021.1.1/sepdk/src/pax/pax.o] Error 1
make[2]: *** [Makefile:1805: /opt/intel/oneapi/vtune/2021.1.1/sepdk/src/pax] Error 2
make[2]: Leaving directory '/usr/src/linux-headers-5.10.3-051003-generic'
make[1]: *** [Makefile:88: default] Error 2
make[1]: Leaving directory '/opt/intel/oneapi/vtune/2021.1.1/sepdk/src/pax'
make: *** [Makefile:208: default] Error 2
failed
From some googling, it seems that the api has been deprecated since 5.10.
Thus, is there a newer version of VTune or any workaround for it.
FYI, I am using VTune 2021.1.1.
Vincent
Kirill_U_Intel
Please, just replace VTUNE_INSTALL_DIR/sepdk/src/pax/pax.c file.
It has just fixes for kernel 5.10+ support
Official public release with 5.10 kernel support will be VTune 2021.2.0.
Thanks, Kirill
Kirill_U_Intel
Hi.
Currently there is no public release with 5.10 kernel support.
I'll connect you for workaround directly.
Kirill
Dan_Boyne
I'm receiving similar errors when compiling the drivers for Vtune under Fedora kernel 5.10.16-200.fc22.x86_64. (Errors pasted below.) Is the work-around available to the public?
/bin/make -C /lib/modules/5.10.16-200.fc33.x86_64/build M=/opt/intel/oneapi/vtune/2021.1.1/sepdk/src/pax LDDINCDIR=/opt/intel/oneapi/vtune/2021.1.1/sepdk/src/pax/../../include LDDINCDIR1=/opt/intel/oneapi/vtune/2021.1.1/sepdk/src/pax/../inc modules PWD=/opt/intel/oneapi/vtune/2021.1.1/sepdk/src/pax -j4
make[2]: Entering directory '/usr/src/kernels/5.10.16-200.fc33.x86_64'
| sget_fc
/opt/intel/oneapi/vtune/2021.1.1/sepdk/src/pax/pax.c:186:22: error: incompatible types when assigning to type ‘mm_segment_t’ from type ‘int’
| sget_fc
| KERNFS_NS
/opt/intel/oneapi/vtune/2021.1.1/sepdk/src/pax/pax.c:282:18: error: incompatible types when assigning to type ‘mm_segment_t’ from type ‘int’
| KERNFS_NS
Kirill_U_Intel
Thanks, Kirill
Dan_Boyne
You rock, Kirill! The replacement pax.c file allowed me to proceed with the build. Many thanks!
RaeesaM_Intel
Glad to know that your issue is resolved and thank you for accepting the solution. We are discontinuing monitoring this thread. Please raise a new thread in case of any further issues.
Raeesa
