I have a failure while trying to build the sampling driver for vtune.
/opt/intel/oneapi/vtune/latest/sepdk/src$ sudo ./build-driver
C compiler to use: [ /bin/gcc ]
C compiler version: 10.2.1
Make command to use: [ /bin/make ]
Make version: 4.3
Kernel source directory: [ /lib/modules/5.10.0-33-amd64/build ]
Kernel version: 5.10.0-33-amd64
Cleaning workspaces ...
Done
Building socperf driver ...
Done
Building sep driver ...
/opt/intel/oneapi/vtune/2024.2/sepdk/src/sys64.o: warning: objtool: SYS_Get_GDT_Base()+0x3: 'naked' return found in RETHUNK build
/opt/intel/oneapi/vtune/2024.2/sepdk/src/sys64.o: warning: objtool: SYS_IO_Delay()+0x0: 'naked' return found in RETHUNK build
ERROR: modpost: "module_mutex" [/opt/intel/oneapi/vtune/2024.2/sepdk/src/sep5.ko] undefined!
make[3]: *** [/usr/src/linux-headers-5.10.0-33-common/scripts/Makefile.modpost:123: /opt/intel/oneapi/vtune/2024.2/sepdk/src/Module.symvers] Error 1
make[3]: *** Deleting file '/opt/intel/oneapi/vtune/2024.2/sepdk/src/Module.symvers'
make[2]: *** [/usr/src/linux-headers-5.10.0-33-common/Makefile:1783: modules] Error 2
make[1]: *** [/usr/src/linux-headers-5.10.0-33-common/Makefile:192: __sub-make] Error 2
make: *** [Makefile:220: default] Error 2
Failed to build the drivers
Relevant information:
$ vtune --version
Intel(R) VTune(TM) Profiler 2024.2.1 (build 628577) Command Line Tool
Copyright (C) 2009 Intel Corporation. All rights reserved.
$ uname -r
5.10.0-33-amd64
$ ls /usr/src/
linux-config-5.10
linux-headers-5.10.0-33-amd64
linux-kbuild-5.10
linux-patch-5.10-rt.patch.xz
linux-source-5.10
linux-source-5.10.tar.xz
I would be grateful for any help on building the driver.
Martin
The kernel version is old, could you upgrade to a new kernel version and try?
Which platform? Did you try with VTune 2025.0?
I'm on Debian 11.
I haven't tried vtune 2025.0 yet.
I have upgraded my kernel to 1.15.**bleep** which seems to have solved my issue.
