Analyzers
5296 Discussions
Failure to launch vtune-gui.. (version is 2021.1.1) .. on CentOS Linux 7 (Core)
ABhinav_Kumar
Installed the VTune profiler from this link (https://software.intel.com/content/www/us/en/develop/tools/oneapi/base-toolkit/download.html#operatingsystem=Linux&#distributions=YUM%20Package%20Manager
While launching the vtune-gui , gui is failing to launch with the following error-messages:
vtune/2021.1.1/backend/bin64/amplxe-node: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.20' not found (required by vtune/2021.1.1/backend/bin64/amplxe-node)
vtune/2021.1.1/backend/bin64/amplxe-node: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.21' not found (required by vtune/2021.1.1/backend/bin64/amplxe-node)
vtune/2021.1.1/backend/bin64/amplxe-node: /usr/lib64/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by vtune/2021.1.1/backend/bin64/amplxe-node)
Node.js HTTP port is not availableFailedTo Access Critical Module
Failed to launch VTune Amplifier GUI...
AbhishekD_Intel
Hi Abhinav,
As this thread is more related to Vtune, we are moving this thread to the appropriate forum.
Please expect a reply from the below forum.
https://community.intel.com/t5/Analyzers/bd-p/analyzers
Warm Regards,
Abhishek
Kirill_U_Intel
could you provide output for ldd call?
ldd VTUNE_INSTALL_DIR/vtune/2021.1.1/backend/bin64/amplxe-node
linux-vdso.so.1 => (0x00007ffe43d85000)
libdl.so.2 => /lib64/libdl.so.2 (0x00007f93d796f000)
libstdc++.so.6.0.36 => not found
libstdc++.so.6.0.35 => not found
libstdc++.so.6.0.34 => not found
libstdc++.so.6.0.33 => not found
libstdc++.so.6.0.32 => not found
libstdc++.so.6.0.31 => not found
libstdc++.so.6.0.30 => not found
libstdc++.so.6.0.29 => not found
libstdc++.so.6.0.28 => not found
libstdc++.so.6.0.27 => not found
libstdc++.so.6.0.26 => not found
libstdc++.so.6.0.25 => not found
libstdc++.so.6.0.24 => not found
libstdc++.so.6.0.23 => not found
libstdc++.so.6.0.22 => /opt/intel/oneapi/vtune/2021.1.1/backend/bin64/./../../lib64/libstdc++.so.6.0.22 (0x00007f93d68ea000)
libstdc++.so.6 => /opt/intel/oneapi/vtune/2021.1.1/backend/bin64/./../../lib64/libstdc++.so.6 (0x00007f93d776e000)
libm.so.6 => /lib64/libm.so.6 (0x00007f93d746c000)
libgcc_s.so.1 => /opt/intel/oneapi/vtune/2021.1.1/backend/bin64/./../../lib64/libgcc_s.so.1 (0x00007f93d7255000)
libpthread.so.0 => /lib64/libpthread.so.0 (0x00007f93d7039000)
libc.so.6 => /lib64/libc.so.6 (0x00007f93d6c6b000)
/lib64/ld-linux-x86-64.so.2 (0x00007f93daf6c000)
RaeesaM_Intel
Thank you for your patience. We are forwarding this case to subject matter experts. As a workaround , you can try launching VTune GUI using web server.
In order to enable VTune web server in your devcloud kindly follow the below steps:
Step 1 : Login to devcloud compute node.(Note the compute node name Example: s001-n011 )
Step 2 : Navigate to /opt/intel/inteloneapi/vtune/2021.1-beta08/bin64/
Step 3 : Start the web server by running ./vtune-backend --web-port=8880
Step 4 : Open another terminal and run ssh -L 8880:localhost:8880 devcloud then tunnel to the compute node using ssh -L 8880:localhost:8880 s001-n011 (Replace s001-n011 with your compute node name). This is the two way tunneling part.
Step 5 : Now run the URL in browser which we received after starting web server(3rd step).Example : https://127.0.0.1:8880?one-time-token=****** You will be prompted to enter the passphrase once the url is accessed in your web browser, also you can set any passphrase of your choice.
Note: You need not to pass --allow-remote-ui as you are accessing from localhost.
Refer the following link for more details :https://software.intel.com/content/www/us/en/develop/documentation/vtune-help/top/launch/web-server-ui.html
Raeesa
Mariya_P_Intel
@ABhinav_Kumar, there was no feedback from you for more than a week. I assume that the above comments helped you. We are discontinuing monitoring this thread. Please raise a new thread in case of any further issues.
Thanks, Mariya
