Analyzers
5340 Discussions
Finalization error (createEventInstance: wrong uniqueTid)
alrheis__ghassan
Hey,
I am attempting to profile a threaded version of a Fortran simulation using VTune. The threading was done using OpenMP and the Intel Fortran compiler. After completing data collection I get the following error message during finalization:
Cannot load data file 'C:\Users\...\r001hs\data.0\3740-14804.0.trace' (createEventInstance: wrong uniqueTid)
This leads to inaccurate results showing wrong total wall time or wrong thread count/histogram.
I managed to do a couple of analyses before but, since this started happening, I don't seem to be able to redo them without this error. Also, I don't get this error when I profile the single thread version. I don't know where to start with troubleshooting this so any tips will be appreciated.
Software and system information:
  • I am using Intel VTune Amplifier GUI 2019 Update 2 Product Build 588069. Analysis type is Hotspots and its running on my local machine. Also, I always run it as admin.
  • Compiler: Intel fortran compiler 19.0 update 1 for the Visual Studio 2017 environment. I compile with the following options:
/nologo /O2 /fpp /Qopenmp /module:"Release\\" /object:"Release\\" /Fd"Release\vc150.pdb" /libs:static /threads /c /Zi /debug:inline-debug-info
  • My OS is:  64 bit Windows 10 Enterprise version 10.0.17134 Build 17134.
  • My processor is: Intel Core i7-7800X @ 3.50GHz with 12 Logical Processors
Ghassan
Denis_M_Intel
 Is the "Collect highly accurate CPU time" option enabled in your VTune Analysis? Can you try to disable it and re-run the collection?  - It should be possible to change it in the custom collection copied from "Hotspots"accurate_cpu_time.png
Denis_M_Intel
Dmitry_P_Intel1
While the problem is being triaged you can try hotspots analysis with stacks based on HW events (if Intel SEP driver is installed and available on your system):
Thanks & Regards, Dmitry
alrheis__ghassan
Hey thanks for your replies!
I ran an analysis without the accurate CPU time option enabled and didn't encounter the error. The results are very similar to what I got before. Given this would you know how to address the problem? I might not need to but its nice to have for the record or in case this causes issues later on.
I couldn't get results with Hardware Event-Based Sampling because I have Credential Guard enabled and I couldn't disable it. I used this tool but after rebooting it was enabled again. It might be because the group policy controls this. I ignored the warning and ran anyway but I got a database error during finalization.
Ghassan
