Analyzers
5285 Discussions
Flow Graph Collector, documentation links error 404, where is the documentation?
MickeJ-IUA
Hi, I want to use the Flow graph analyzer included in Advisor but the documentation links are 404. Where is the documentation for Scalability Analyses and Collecting Trace from Applications referenced below?
https://www.intel.com/content/www/us/en/docs/advisor/user-guide/2025-0/launching-the-flow-graph-analyzer.html
The Flow Graph Collector allows you to capture a topology and execution trace information of a running flow graph application. You can load this captured data to the Flow Graph Analyzer for closer inspection of the graph described by the application and the performance data for the graph. See the Scalability Analysis section for the steps to build your application with enabled traces and to capture the trace information. See the Collecting Traces from Applications for instructions on how to use the Flow Graph Analyzer for analyzing the performance of flow graph applications after a trace has been collected.
