Analyzers
5341 Discussions
Getting error [Instrumentation Engine]: Pin is out of memoryPin is out of memory
JayCarter
I am trying to Profile our app and upgraded to 2023.2.0 and now I am getting error:
When using Basic User Mode Hotspot.
Advanced works okay.
Window 10 OS
JayCarter
NOTE: This is when attaching to the process.  It also kills the process I am attaching to.
AthiraM_Intel
Could you please share the following details to debug your issue further:
  1. Hardware details
  2. Sample reproducer code, commands and exact steps you followed
  3. Self checker log
  4. screenshots of the error
JayCarter
1) These are HP Z840's.
Intel(R) Xeon(R) CPU E5-2690 v3 @ 2.60GHz 2.60 GHz (2 processors) - Windows 11
Intel(R) Xeon(R) CPU E5-2683 v4 @ 2.10GHz 2.10 GHz (2 processors) - Windows 10
2) This is just Attach to process - User Mode Sampling.
3) How do I do perform "Self Checker Log"
4) Here is the result - NOTE the app is killed after the error occurs
JayCarter
Here is the self-check log.
JayCarter
And User Mode Sampling works if I use Launch option v Attach option.
JayCarter
This must be application specific.
Another app built form the same code base works when Attaching with User Mode Sampling.
AthiraM_Intel
Thank you for sharing the details.
Could you please share the sample reproducer code, so that we can try out the same from our end.
AthiraM_Intel
We have not heard back from you. Could you please share a sample reproducer code (sample reproducer is an exact replica of your working sample) to debug your issue further.
AthiraM_Intel
We have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
