Analyzers
5341 Discussions
Getting tuning advice at source code level, when using openmp
sachini1
Whenever I go to the source code view from hotspots view, it gives mea sayingmessage,
"The function you have selected has multiple versions of source code. This may be due to several jit compilations. You will be taken to hotsports by address view. You can then proceed to source code view"
is this becuase i use openmp pragmas in my program? (just an assumption because i dont get this when running other programs)
in the source code view when i try to get tuning advice it produced an error saying 'Internal error: 1700". and there's no advice given at all.
will be greatful if someone can help me find a solution to this problem.
thanks in advance!
Sachini
