Analyzers
5341 Discussions
Heap corruption when profiling .Net App
christensen__david
I'm regularly seeing a problem with .Net (C#) apps which run perfectly well outside VTune, but which when I attempt to profile them crash almost immediately with a stack trace in RtlFree and a message of heap corruption.
Is this a known problem? Is there a workaround?
This is using Vtune 2018 update 3.
David
Denis_P_Intel
Hello David,
Is there a chance to get your app to reproduce the issue locally?
Thanks, Denis
christensen__david
The full app is commercially sensitive, but I'll try to produce a cut-down version that exhibits the problem.
David
christensen__david
If it helps, here's the call stack
