Analyzers
5307 Discussions
How to I get the "product unlock code" for a evaluation version of VTune
Cristian_T_
I downloaded VTune Amplifier XE, got the registration code, registered it and when I try to install it I got the following message:
In Order to complete the offline activation process, you will need to use a system that is connected to the internet.
1. On the connected system, go to:
https://registration.intel.com/RegCenter/remoteactivation.aspx
2. Enter this produce activation code on the above web page:
XXXX-XXXX-XXXX-XXXX-XXXX-XXXX-XXX
3. Save....
Well, going to the page above and entering the product activation code results in a message that says that for evaluation version I have to go to another page, where, when I go, I can't find any link suggesting anything related to getting the "product unlock code"
Please note that on the target machine I cannot possibly have internet connection so offline activation is the only choice I have.
Please help,
Cristian
Feilong_H_Intel
Hi Cristian,
I've sent a license file to you thru email. Please install VTune Amplifier XE with it, rather than an activation code. Please let me know if there is anything else I can help.
Thank you.
Feilong H.
Intel Developer Support
Tools Knowledge Base:  http://software.intel.com/en-us/articles/tools
Michael_H_4
I am having the same problem activating the evaluation version on an isolated platform.  Can you please send me the license file?  Thanks!
Feilong_H_Intel
Hi Michael,
Please send me your serial number by click "Send Author A Message" on top of this reply.  I'll send you the license file.  BTW, you can do that by yourself.  Just log into https://registrationcenter.intel.com with your login ID (usually your email).  Click the product you are evaluating.  Then you will see your serial number.  Click "Manage" on the right.  You will see a "resend license file" button.  Hope this helps.
Feilong
