Analyzers
5307 Discussions
How to do Basic hotshot profile with intel 2015 + VS 2012 + MPI
Wee_Beng_T_
I just bought the Intel studio 2015 cluster edition windows. I need to do Basic hotshot profile with intel 2015 + VS 2012 + MPI for my cfd code. I am using a workstation with 2 cpu (2x12 cores). Using 1 cpu, I managed to the analysis successfully.
I can run my code in parallel using intel's wmpiexec.exe. I can also run my code thru VS 2012 by:
setting the launch command (Configuration Properties - Debugging - Command) to the full path for mpiexec.smpd.exe (eg C:\Program Files (x86)\MPICH2\bin\mpiexec.exe)
setting the arguments (Configuration Properties - Debugging - Command Arguments) to -n xxx $(TargetPath) where xxx is the no. of cpu
However, I can't get it to work with vtune if I need to use more than 1 core.
It gives the wrong function for top hotspots and my cpu usage is 0.
Any solution?
Thanks!
Dmitry_P_Intel1
Could you please provide VTune command line or GUI project properties parameters on how do you launch VTune collection? Or you invoke it in VS?
Thanks & Regards, Dmitry
Wee_Beng_T_
I tried both - within VS and launching vtune directly.
For 1 cpu:
correct results:
2 cpu:
error result:
So how should I start my MPI code so that the correct info is captured and analyzed?
Thanks!
