Analyzers
5286 Discussions
How to include source file when drilling down to assembly level
drew_woods
When I'm using Vtune to analyse functions of modules and it cannot find the source, it seems to behave in one of two ways:
It either asks for the missing source file, and then allows me to mix source and assembly code together,
or it doesn't ask me for source code at all, and I can only view the assembler.
How do I specify the source code manually, if it doesn't prompt me automatically?
Thomas_W_Intel
Drew,
Might it be that the object files, where you aren't asked for a source file, do not contain debug information? (e.g. because they were not compiled with -g or because they are stripped) There is an option that let's you choose if you want to be warned about this or VTune should simply show the assembly code. I suspect that the first variant is turned on for you.
Kind regards
Thomas
drew_woods
Thanks for the reply Thomas, I'll have a look into it
