Analyzers
5307 Discussions
How to know the exact name of the function displayed in vtune?
xulei_ict
I am using vtune to count the time, but it function notation is func@0x?????. But I'm not sure exactly which part of the code this function refers to. How can I get the stats to show readable function names. These functions should belong to some dynamic library.
RemyaP_Intel
If the VTune Profiler does not find debug information for the binaries, it statically identifies function boundaries and assigns hotspot addresses to generate pseudo names func@address for such functions
To view the CPU time, click on each line under the tab “Sync Object/function/Call Stack”
On the right side of the page,> under "Call Stacks" > double click on the .c file if present.
A new tab will open, which contains the source and assembly. Here, you can find the CPU time utilization wrt the source line.
Note: Line of code that takes negligible time for execution won’t be displayed.
Remya Premdas
RemyaP_Intel
We haven't received any update. Did your issue got resolved?
Remya
RemyaP_Intel
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Remya Premdas
